Cisco AP is not joining WLC
waqas.arshad
I have connected a NEW ap in our network but it is not join the WLC.  AP is is trying to download the image from WLC but  it is getting failed. Ap Model is 2700 series.
I can see the following errors in AP CLI
*Jan 16 16:01:26.023: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_record.c:169 Pkt too old last_seq_num : 11109,Received sequence num: 2 distance: -11107
*Jan 16 16:01:26.027: Using SHA-2 signed certificate for image signing validation.
*Jan 16 16:01:26.095: %PKI-3-CERTIFICATE_INVALID_EXPIRED: Certificate chain validation has failed. The certificate (SN: 4E78A210000000000007) has expired. Validity period ended on 21:43:46 UTC Dec 4 2022
*Jan 16 16:01:26.095: Image signing certificate validation failed (1A).
*Jan 16 16:01:26.099: Failed to validate signature
*Jan 16 16:01:26.099: Digital Signature Failed Validation (flash:/update/ap3g2-k9w8-mx.153-3.JPJ9/final_hash)
*Jan 16 16:01:26.099: AP image integrity check FAILED
Aborting Image Download
Download image failed, notify controller!!! From:8.5.164.0 to 17.3.6.76, FailureCode:3
Anyone can help to resolve the issue?
Warshad
balaji.bandi
What WLC Model. what Code running -
First look the Cert is expired :
check the controller version matrix supported ?
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
BB
waqas.arshad
Thank you for reply Balaji. I think its a bug. I found this and i this its relevant.
https://bst.cisco.com/bugsearch/bug/CSCwd80290
Arshad
 - Yep  , this is the corresponding field notice : https://www.cisco.com/c/en/us/support/docs/wireless/aironet-700-series-access-points/218447-ios-ap-image-download-fails-due-to-expir.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
Yes field notice about this below for anyone else reading:
