Cisco Ap not join WLC 3504
VKMH
Dear Team
We have installed WLC 3504 (software version 8.5.140.0) and AP model-C 9105AXI-E. Cannot join the AP for this controller can you please support what's issue is not join. need to be upgrade controller?
5 Replies 5
Mark Elsen
  - The software version on the controller is too old and can not support that AP model. You need to use 8.10.196.0
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Dear Marce,
Thanks for your replay. I will upgrade software and let you know.
Software Download 3504 Wireless Controller 8.10.196.0
Hi marce
I upgrade 8.10.196.0 Its working fine thanks for your support.
Rasika Nayanajith
As pointed by Marce, you require an WLC upgrade. Pls find the reference link below for each AP supported code versions.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#ctrl_release-ap-support
Rasika
*** Pls rate all useful responses ***
