Cisco AP Speed İssue
tolga.kulaber
I am using cisco aironet C1600 (AIR-SAP1602I-E-K9) model AP. Although 802.11n is installed, the speed provided by wireless does not exceed 50Mbps. I updated the encryption method to be WPA-2 aes-ccm and enabled the WMM feature, but nothing changed. I am sharing the AP config in the attachment, can you help?
Hi Leo,
I tested it with a different AP of the same model and saw that I could get 85Mbps speed. In summary, the current AP is faulty. Thank you for your help.
16 Replies 16
balaji.bandi
how about end device Wireless NIC ( Drivers) have you tried any other latest device?
BB
Arshad Safrulla
is the client connected over 2.4 radio or 5?
What the WAN speed?
Hows the speedtest conducted? Ookla or Iperf?
What is the client OS and model?
Does the client support 5GHz?
Leo Laohoo
  1. What is the wireless NIC and what is the wireless NIC driver?
  2. How many wireless clients are used to "test" the speed, only one?
tolga.kulaber
Thank you everyone for your answers.
I will answer your questions one by one.
My wan speed is 100Mbps. When I test the cable at the end of the ethernet cable that is inserted into the Cisco AP, I get 95Mbps speed.
I'm doing the speed measurement with home oakla, but I'm downloading files from FTP to double check (4.7MiB/s x 8=37Mbps)
Clients have 5G support. I'm testing with multiple devices. Laptop, Apple, Samsung etc.
During the test stages, I paid attention to the fact that only one client was connected.
1602E means an AP with external antenna.  What is the model of the antenna and how many antennas installed on this AP?
1602E also means 802.11n only.  What happens if 2.4 Ghz is disabled?  What result with www.fast.com?
There is no external antenna over the model AP I am using. I tried disabling 2.4Ghz but the result did not change. Fast.com speed test result is 37Mbps...
I asked for the config file from a friend who uses the same AP and there is no difference. With the same version and the same AP, it can reach higher speeds.
Ooops.  Mea culpa.  I misread the model.
Show us the config.
HOME_GATEWAY#sh run
Building configuration...
Current configuration : 4938 bytes
! Last configuration change at 08:03:46 +0300 Mon Mar 1 1993 by admin
version 15.2
no service pad
service password-encryption
hostname HOME_GATEWAY
logging rate-limit console 9
enable secret 5 $1$cyfD$1qSN09QyuJoHEUGp81UF7/
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone +0300 3 0
no ip routing
no ip cef
ip domain name homegateway
dot11 syslog
dot11 ssid HOME_GATEWAY_2.4Ghz
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 046F0701042D4E5C58404B4F444A
dot11 ssid HOME_GATEWAY_5Ghz
   authentication open
   guest-mode
power inline negotiation prestandard source
crypto pki trustpoint TP-self-signed-1623076087
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1623076087
 revocation-check none
 rsakeypair TP-self-signed-1623076087
crypto pki certificate chain TP-self-signed-1623076087
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31363233 30373630 3837301E 170D3933 30333031 30303038
  30395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 36323330
  37363038 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D446 129B9A58 6842AEBC 21C2D854 B4E04671 6F04A781 AE391529 E77700B7
  6966791C 3E9B6A4C 6B1FDA46 49FFFE84 1AFF6668 28799DA3 96FF208B 7438AB70
  6136FB34 B8557F74 BEA3F289 1D7A1D87 0C1A6735 ABA3C4C1 613ABC76 31347A9E
  85FB427A 7367B4EE 45705FBD 7611688E 827FFACB F67262CD D60201C4 DE1AAC0E
  C82B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1486AB83 010D4C0B B9E2B06E DDE70C07 304BBBA9 67301D06
  03551D0E 04160414 86AB8301 0D4C0BB9 E2B06EDD E70C0730 4BBBA967 300D0609
  2A864886 F70D0101 05050003 81810033 2ECE3D3A 92357915 D826A453 DB495EA0
  9D4EDAF8 BC85526D F6C51DA6 3B1FE549 4977222C E4890638 9E3E90FA 9F173B38
  E73B5DC0 3CB5B0D7 962A7641 FE5708A5 A2AFDB1C 821746F2 34FA5578 77C7FA3E
  06DD158B BD00FE6A C8A46C22 5C817A5B 8480EED2 553D1F29 96974165 4FCA8C1F
  768E04E1 F219D7A6 2FBF2A00 7B9397
        quit
username Cisco password 7 01300F175804
username admin privilege 15 secret 5 $1$eyEE$9rqJ0ghDJeeqHj3cYKzfI/
bridge irb
interface Dot11Radio0
 description 2.4GHZ_SSID
 bandwidth 10000000
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 antenna gain 0
 stbc
 beamform ofdm
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 input-address-list 700
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 description 5GHZ_SSID
 bandwidth 10000000
 no ip address
 no ip route-cache
 antenna gain 0
 no dfs band block
 stbc
 beamform ofdm
 speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 channel width 40-above
 channel 5680
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address 192.168.1.254 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
access-list 111 permit tcp any any neq telnet
access-list 700 permit 00c2.c61e.f7cb   0000.0000.0000
access-list 700 permit c83c.85da.87a1   0000.0000.0000
access-list 700 permit 08c5.e121.7348   0000.0000.0000
access-list 700 permit 2079.18cf.74f2   0000.0000.0000
access-list 700 permit ec5c.68c0.8c1d   0000.0000.0000
access-list 700 permit f8da.0cc4.03f1   0000.0000.0000
access-list 700 permit 9cad.9767.8bd7   0000.0000.0000
access-list 700 permit 80ce.b9c8.8533   0000.0000.0000
access-list 700 deny   0000.0000.0000   ffff.ffff.ffff
bridge 1 route ip
line con 0
 access-class 111 in
line vty 0 4
 access-class 111 in
 transport input all
end
HOME_GATEWAY#
basic-6.0 basic-9.0
Get rid of that.
Post the complete output to the command "sh interface g0".
It could be speed/duplex mismatch.
I removed the commands below.
basic-6.0 basic-9.0
HOME_GATEWAY#sh int gigabitEthernet 0
GigabitEthernet0 is up, line protocol is up
Hardware is PowerPC Ethernet, address is c08c.60be.2cf7 (bia c08c.60be.2cf7)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 255/255, rxload 1/255
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is T
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/9355/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 200000 bits/sec, 68 packets/sec
5 minute output rate 845000 bits/sec, 89 packets/sec
6533298 packets input, 3706574217 bytes, 0 no buffer
Received 28597 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
2834895 packets output, 985580068 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
162 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
txload 255/255
WTF.
Post the complete output to the following commands:
sh version
sh proc cpu history
Thank you so much for trying to help.
HOME_GATEWAY#sh ver
Cisco IOS Software, C1600 Software (AP1G2-K9W7-M), Version 15.2(4)JB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 06-Mar-14 09:39 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
HOME_GATEWAY uptime is 7 hours, 10 minutes
System image file is "flash:/ap1g2-k9w7-mx.152-4.JB4/ap1g2-k9w7-mx.152-4.JB4"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP1602I-E-K9 (PowerPC) processor (revision B0) with 229366K/32768K bytes of memory.
Processor board ID FGL1738W4GE
PowerPC CPU at 533MHz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C0:8C:60:BE:2C:F7
Part Number : 73-14671-04
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC17345SB7
Top Assembly Part Number : 800-38552-01
Top Assembly Serial Number : FGL1738W4GE
Top Revision Number : A0
Product/Model Number : AIR-SAP1602I-E-K9
Configuration register is 0xF
HOME_GATEWAY#
HOME_GATEWAY#
HOME_GATEWAY#
HOME_GATEWAY#
HOME_GATEWAY#
HOME_GATEWAY#sh processes cpu history
HOME_GATEWAY 10:10:50 AM Monday Mar 1 1993 +0300
1111166666 3333322
100
90
80
70
60
50
40
30
20
10 *****
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
100
90
80
70
60
50
40
30
20
10 * ****
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
6281610
100 *
90 *
80 *
70 *
60 *
50 *
40 *
30 *
20 * * * *
10 *******
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
Can we see the output to the command "sh interface dot111"?
of course,
HOME_GATEWAY#sh int dot11Radio 1
Dot11Radio1 is up, line protocol is up
Hardware is 802.11N 5GHz Radio, address is e8ed.f3ec.14f0 (bia e8ed.f3ec.14f0)
Description: 5GHZ_SSID
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 1000 usec,
Input queue: 0/9355/0/0 (size/max/drops/flushes); Total output drops: 12981
Output queue: 0/30 (size/max)
5 minute input rate 995000 bits/sec, 182 packets/sec
5 minute output rate 1770000 bits/sec, 197 packets/sec
903016 packets input, 260334372 bytes, 0 no buffer
Received 32393 broadcasts (0 IP multicasts)
1336803 packets output, 1566700880 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
