Cisco AP9115 interface BVI
heyjunsun
Level 3
Level 3
hello!
I have a question during the setup.
The products that our company used before are 1600 and 1700 models
In that model, the command example
"bridge irb ( BVI eanble ) "
" interface Dot11Radion0 "
" ssid test "
" station-role root"
"interface BVI"
"interface GigabitEthernet1"
"bridge-group 1"
When these commands are used, they are not active.
If not, I wonder what other commands have been replaced by.
In the meantime, I set up interface Dot11 with ssid creation and ip address in BVI, but it is difficult because most of the commands are not used in 9115AP.
I need your help
JPavonM
Catalyst 9100 series cannot be configured in autonomous mode, and thee only option is to convert them into eWC mode (the evolution of previous Mobility Express) and configure it.
https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html
https://www.youtube.com/watch?v=c81VQCeqGNY
https://www.youtube.com/watch?v=oS68E25wc4A
5 Replies 5
JPavonM
hello JPavonM
The version I'm currently using is "C9800-AP-universalk9.16.12.04a
Can I use version 17.09.04 as shown in the picture?
Mark Elsen
        - FYI : https://mrncciew.com/2022/07/11/cisco-9100-ap-as-wgb/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
hello marce1000
I'm confused about what I understand.
Is the WGB from the homepage you mentioned the same as the EWC setting? And on the Cisco homepage, there are three types: "Embedded Wireless Controller", "IOS XE Software AP Service Pack", and "Lightweight AP Software", so which version should I choose over 17?
No workgroup bridge is when you use 2 APs to create a bridge between 2 LAN segments.
If you are looking for a modern replacement for autonomous APs (which it sounds like you are) then you need to use EWC as @JPavonM  advised.
When selecting a version refer to the latest TAC Recommended link below.  Currently that is:
Cisco recommends 17.9.4 + SMU_CSCwh87343 + APSP (as needed) OR 17.9.4a + APSP(as needed) for all deployments.
But note that SMUs and APSPs are not available for EWC - only for 9800 hardware appliances and 9800-CL.
So currently 17.9.4a is the TAC recommended version to use.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
