Cisco APs with the same SSIDs
judson.nascimento
Community Member
I have some Cisco APs 1200 Series and when I put these to broadcast the same SSID the users get disconnect on instants.
What is the problem?
What I will need to do to put the APs to serv the same SSIDs?
robert.wright
Level 5
Level 5
Likly your APs over lap one another. Do a search on the forums for site survey and you will turn up several good conversations.
robert.wright
Level 5
Level 5
Very good!
I have seen some documents that can help me. Thank you!
