Need help with Access Point!!!
Chrisneedshelp
Community Member
Ok I don't know which one I have, access point or wireless router. I think its a Linksys WRT54G it says cisco on it though. I know linksys and Cisco are one. Ok my question is.. I'm trying to connect 3 PSP's a DS and a Wii to the access point. I went to 192.168.1.1 but it shows no wireless security tab. My access point says its WPA encryption. I need to change it but I cant!! Its plugged in and all three lights are on. Please help.
jackyoung
Level 11
Level 11
I suggest you to check the supporting list of the wireless AP from those game player companies.
If it is not supported, you can't do anything. Moreover, please specify the requirement and I don't know the requirement from those players.
Hope this helps.
