Cisco Business 140AC Wireless Access Point & Firepower 1010
1timcisco
I have a Firewpower 1010 that has 2 POE ports 1/7,1/8 that have 53.5VDC voltages.  When I connect the 140AC access point it will not power on and according to the specs its requires 48-56V.  I am using FMC to manage this device.  I am not using a POE injector. Has anyone seen the POE not working before on the Firepower 1010?
1timcisco
Turns out you have to be running firepower version 6.6, version 6.4 does not have POE on 1/7,1/8.  Atfter I updated the device the POE+ was active.
8 Replies 8
I just connected an AP to the PoE-port of my Firepower 1010 and the AP is powered up:
> show power inline
Interface     Power   Class   Current (mA)   Voltage (V)
Ethernet1/7   ON      4       113.00         53.00
Are you managing your firepower 1010 with FMC?  What CLI did you imput that command, I dont have it as an option.
It is managed by FMC and is running version 6.6.4. The CLI is the one that you get through SSH.
marce1000
 - You may find this thread useful :
            https://community.cisco.com/t5/network-security/firepower-1010-6-6-poe-problem/td-p/4077009
 M.
marce1000
 - Ref : https://www.cisco.com/c/en/us/td/docs/security/asa/asa914/asdm714/general/asdm-714-general-config/interface-switch.html#task_xz1_xhy_lhb
          Pay attention to Step 7 and or review current POE status (e.g.)
 M.
1timcisco
I started a new thread on this but version 6.6 does not work with 140AC for me.  I am attempting to get the newer firmware and 150 watt power supply.
Regards.
