01-18-2024 12:27 PM
Hello.
Trying to figure out the configuration via WLC on how to set up a C9120AXE-B to use the 4 ports on its face for indoors and the DART cable / AIR-ANT2566D4M-R antenna for outdoor use. Do we need to set antenna gain and TX power for the DART setup?
From what I was told, we have to config AP as "XOR". Do we use slots? I think we have it working with 5 GHz on the 4 ports on face and the 2.4 GHz on the DART. However, I think I should be seeing stronger signal from external antenna. (I have temp setup with external antenna in a window about 5 ft off of the ground. I'm seeing around -80dB about 150 feet away. Using Wi-Fi app on cell phone to measure signal from AP.)
01-22-2024 07:57 AM
there are multiple versions of ANT2566, you could have selected the self-identifying model instead of the -R=
check Cisco Catalyst 9120AX Series Access Point Getting Started Guide - Cisco
section about self-identifying antenna's and port-A / -B
01-22-2024 08:09 AM
01-22-2024 11:45 PM - edited 01-22-2024 11:50 PM
no, in the WLC you cannot select the antenna model, you can only specify the "antenna gain"
Configuration -> Wireless -> Access Points -> close "all access points", open "dual band radios"
double-click on an access point -> antenna parameters
I found this post Solved: WLC98000 external antenna gain configuration - Cisco Community
it says gain is twice the dBi, but i haven't read this in Cisco documents to confirm this .
also take a look at the online help
Cisco Embedded Wireless Controller for Catalyst Access Points Online Help - Configuring Access Points (tno.nl)
section: Antenna Parameters -> also for SI antenna's "This field is displayed on selected models"
01-22-2024 11:57 PM
Antenna gain value is documented here and it has been always the same way in Cisco (https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/m_configuring_80211_parameters_for_cisco_aps.html#:~:text=specific%20access%20point.-,ext%2Dant%2Dgain,-%3A%20Configures%20the%20802.11b)
01-23-2024 12:17 AM
yes, there it is:
antenna_gain_value —Refers to the external antenna gain value in multiples of .5 dBi units. The valid range is from 0 to 4294967295.
so the factor comes from the units in which it's specified
thank you,
