Cisco Catalyst 9800-40 Wireless Controller
lachimi-sanyasi
Hi Have upgraded Cisco Catalyst 9800-40 Wireless Controller from 17.6.6 to 17.09.05 and it was working fine for few hours. I notice it went back to its previous version when I login next time. Any reason why? please help
18 Replies 18
@lachimi-sanyasi
 How did you do the  upgrade? CLI or web interface? Did you save the configuration?
CLI
I did cli upgrade
Sounds to me something unsave was left and that´s why the old code returned.
Leo Laohoo
If the command "install commit" is not entered and the roll-back timer (I think 8 hours), the WLC will roll back to the previous version.
I did upgrade from GUI
If the upgrade was done using GUI, did anyone click the "Commit" button?
I don't think I saw the commit button. I did save and reload after everything was successful.
From the controller, post the complete output to the command "dir bootflash:*.conf".
Thu Oct 10 2024 13:20:44 GMT+1100 (Australian Eastern Daylight Time)
#dir
Directory of bootflash:/
1387201 drwx 4096 Oct 9 2024 15:50:25 +10:00 .installer
1338241 drwx 4096 Oct 9 2024 15:47:35 +10:00 certs
15 -rw- 916 Oct 9 2024 15:47:09 +10:00 vlan.dat
448801 drwx 4096 Oct 9 2024 15:46:56 +10:00 .prst_sync
13 -rw- 134899 Oct 9 2024 15:46:54 +10:00 memleak.tcl
1428001 drwx 4096 Oct 9 2024 15:46:38 +10:00 dc_profile_dir
43 -rw- 5565 Oct 9 2024 15:43:21 +10:00 packages.conf
1395361 drwx 4096 Oct 9 2024 15:42:26 +10:00 .rollback_timer
1321921 drwx 4096 Oct 9 2024 12:20:07 +10:00 webui_helper
1199521 dr-x 4096 Oct 9 2024 11:15:24 +10:00 .wl_persistent_db
41 -rw- 90 Oct 9 2024 10:14:53 +10:00 act2_cleanup_2024_10_9_0_14_53.log
318241 drwx 4096 Oct 9 2024 09:48:10 +10:00 .cloudm
39 -rw- 90 Oct 9 2024 09:46:21 +10:00 act2_cleanup_2024_10_8_23_46_20.log
38 -rwx 0 Oct 9 2024 09:45:27 +10:00 mode_event_log
1150561 drwx 4096 Oct 9 2024 09:45:27 +10:00 SHARED-IOX
1550401 drwx 4096 Oct 9 2024 09:38:19 +10:00 .dbpersist
962882 -rw- 5542 Oct 9 2024 09:29:41 +10:00 C9800-40-universalk9_wlc.17.09.05.SPA.conf
962884 -rw- 37292247 Oct 9 2024 09:29:40 +10:00 C9800-rpboot.17.09.05.SPA.pkg
962883 -rw- 1414837264 Oct 9 2024 09:28:51 +10:00 C9800-mono-universalk9_wlc.17.09.05.SPA.pkg
37 -rw- 1451859235 Oct 9 2024 09:26:57 +10:00 C9800-40-universalk9_wlc.17.09.05.SPA.bin
35 -rw- 29897 Oct 9 2024 09:12:24 +10:00 running-config
579364 -rw- 35961379 Apr 23 2024 12:30:26 +10:00 C9800-rpboot.17.06.06a.SPA.pkg
579363 -rw- 1199731728 Apr 23 2024 12:29:40 +10:00 C9800-mono-universalk9_wlc.17.06.06a.SPA.pkg
34 -rw- 1235484271 Apr 23 2024 12:28:18 +10:00 C9800-40-universalk9_wlc.17.06.06a.SPA.bin
36 -rw- 25083 Apr 16 2024 10:20:51 +10:00 startup-config
33 -rw- 600 Feb 7 2024 00:49:33 +11:00 1707227101124sh_tech.txt
32 -rw- 4209 Jun 2 2023 09:57:39 +10:00 debugTrace_103d.1c0a.b94b.txt
31 -rw- 2710308 Mar 6 2023 15:38:34 +11:00 ra_trace_MAC_acbc.d936.93e0_153822_Austral_Mon_Mar_06_2023.log
29 -rw- 2527 Mar 6 2023 14:41:58 +11:00 debugTrace_8c84.42d2.a504.txt
30 -rw- 25626 Feb 17 2023 10:16:09 +11:00 debugTrace_1859.f560.47e6.txt
27 -rw- 2 Feb 6 2023 12:28:48 +11:00 debugTrace_8c84.42d2.a3b6.txt
28 -rw- 21880 Jan 10 2023 08:16:50 +11:00 backup_2023-1-10_8_16_50.cfg
26 -rw- 2 Jan 6 2023 14:27:46 +11:00 debugTrace_341b.2df9.f404.txt
20 -rw- 22013 Dec 14 2022 10:09:08 +11:00 debugTrace_ac5f.3e41.0e31.txt
21 -rw- 1309961 Nov 18 2022 16:13:37 +11:00 webuiTmp.pcap
19 -rw- 318113 Nov 17 2022 13:15:34 +11:00 HBRAP16-FieldOffice_74a02fc64d50.crash
18 -rw- 2 Nov 9 2022 09:38:55 +11:00 debugTrace_286f.7f88.b4b0.txt
17 -rw- 64371 Nov 8 2022 15:31:29 +11:00 debugTrace_84f1.4754.08e0.txt
22 -rw- 93826 Nov 5 2022 12:37:32 +11:00 debugTrace_002c.c835.e6c0.txt
23 -rw- 25599 Nov 5 2022 12:35:38 +11:00 debugTrace_286f.7f61.8cd4.txt
25 -rw- 577 Nov 5 2022 12:32:17 +11:00 1670894890106sh_tech.txt
24 -rw- 577 Nov 5 2022 12:21:13 +11:00 1670894226264sh_tech.txt
16 -rw- 362475 Nov 3 2022 16:19:44 +11:00 hbrap26-adminL1_74a02fa346b0.crash
1330081 drwx 4096 Sep 1 2022 11:38:39 +10:00 pnp-tech
1232164 -rw- 33230525 Jul 22 2022 21:07:58 +10:00 C9800-rpboot.17.03.04c.SPA.pkg
1232163 -rw- 1255289872 Jul 22 2022 21:07:16 +10:00 C9800-mono-universalk9_wlc.17.03.04c.SPA.pkg
14 -rw- 1288364809 Jul 22 2022 21:03:32 +10:00 C9800-40-universalk9_wlc.17.03.04c.SPA.bin
456961 drwx 4096 Jul 22 2022 20:54:25 +10:00 guest-share
301921 drwx 4096 Jul 22 2022 20:54:19 +10:00 onep
252961 drwx 4096 Jul 22 2022 20:54:19 +10:00 pnp-info
236641 drwx 4096 Jul 22 2022 20:53:20 +10:00 ss_disc
12 -rw- 5242880 Jul 22 2022 20:53:20 +10:00 ssd
11 drwx 16384 Jul 22 2022 20:43:13 +10:00 lost+found
26975526912 bytes total (17632714752 bytes free)
most likely the cause
If you do not run the install commit command within 6 hours of the install activate issu command, the system will revert to the original commit position. You can choose to delay the commit using the Delayed Commit procedure.
-hope this helps-
How do I do that from GUI can you please tell me?
Also, which version of IOS is the latest and stable one for the Cisco Catalyst 9800-40 Wireless Controller? Any suggestion?
>...Also, which version of IOS is the latest and stable one for the Cisco Catalyst 9800-40 Wireless Controller? Any suggestion?
           - FYI : https://software.cisco.com/download/home/286316412/type/282046477/release/Dublin-17.12.3
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
