Difference between bundle mode and install mode on WLC upgrade
Sam Caprio
Frequent Visitor
Frequent Visitor
Difference between bundle mode and install mode on WLC upgrade?
What is recommended while upgrading the 9800-80 WLC?
is there any difference in features or any other factor between the modes?
Mark Elsen
  - There are no differences in features once the 9800-80 is running , but install mode is more optimal as
 the exec functionality is distributed amongst packages , whilst in bundle mode you have a monolithic large
 bin file to boot.
                                                       So install mode is prefered
    Appendix :  Consider this procedure mandatory for optimal use of your  9800-80 controller's (configuration) ;  use the
                      CLI command  show tech wireless and feed the output from that into Wireless Config Analyzer
                      use the full command as denoted in green , do not use a simple show tech as input for this procedure
                                     It is also advised to do this  after an upgrade (e.g.)!!
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
@Sam Caprio hi, there is no feature difference between these modes. install mode is preferred by cisco due to efficient functionality.
Good luck
KB
Rich R
The most important difference (in my opinion) is that you can only install SMU and APSP when running in install mode.
Install mode is the Cisco recommended mode.  Bundle mode is usually only used in recovery situations.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
