Cisco Catalyst 9800-CL Wireless Controller-NTP Information Disclosure
Hello, everyone.
Do we have a Cisco Catalyst 9800-CL Wireless Controller17.9.2, which is accusing vulnerability (NTP Information Disclosure Vulnerability), has anyone applied the fix on a WLC for this case? Could we help?
6 Replies 6
Scott Fella
Are you looking for help or stating that you can help out?  Most vulnerabilities that have a fix are documented or if there is not a fix, are part of field notices.
-Scott
Sorry, I'm in need of help with the case!
Can you provide more information?  I don't understand what you are asking?
-Scott
marce1000
  - As stated by Scott , post exact message or info you are referring too (or controller log ?) , if for instance reported by a security scanning tool (?). Whilst you are add it ; review your 9800-CL    configuration with the CLI command : show  tech   wireless , have the output analyzed by  https://cway.cisco.com/tools/WirelessAnalyzer/  , please note do not use classical show tech-support (short version) , use the command denoted in green for Wireless Analyzer.               Checkout all advisories and or related to NTP (too - e.g.)
 M.
@marce1000  tks , I'll do that, and let you know if it worked.
Rich R
@Leonardo Marciano  why do you think 17.9.2 has this vulnerability?
What is the CVE number of the vulnerability you think it's affected by?
