Cisco Catalyst 9800-CL Wireless Controller
I have deploy WIFI in my institute using WLC-9800 controller with around 200 access point (C-9155 Axi & 9105) model. I have created simple one  Wlan and profiles with different vlan as per building, my access point is connected with WLC but problem is 1st-  Vlan Assigned to the building  is not giving its network IP
2nd- Client connected to wifi suddenly get no internet and after some time it restore automatically
3rd- Also notice that traffic is going on my WLC instead of My core switch (9600) as result getting drop and latency in my network
Please help to restore this issue
Jerome BERTHIER
Level 7
Level 7
Hello
So you may address these problems in this order :
- fix the drop and latency issue. You may have oversubscrided the distribution system somewhere. Check for troughput, CPU, errors on every stage between the APs and the WLC
- fix the DHCP issue on the vlan bound with the WLAN
- fix the "suddenly get no internet" state which can be same issue as 3rd point. Is it a DNS issue ? a drop issue ?.... basic IP connectivity debug here
jagan.chowdam
Start by validating your C9800 controller configuration - "wireless config validate"
Then, check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output.
  • Make sure you verify your Layer 2 & Layer 3. Simple verification such as pinging building VLAN SVI's from WLC WMI IP will be a good indication that your Layer 2 & Layer 3 configs are OK.
  • verify Ip helper address configured on upstream core switch pointing to your DHCP server (Also ping SVI, IP helper add and DHCP server IP from WLC WMI).
Once you go through the config analyzer and debug analyzer, you can post the output here to others to analyze and provide feedback.
Jagan Chowdam
/**Pls rate useful responses**/
