Cisco CMX Analytics difference between version and statistics
Eivinas
Community Member
Greetings,
We decided to upgrade our Cisco CMX from 10.2.3-34 version to CMX 10.3.1-35.
And we have been confused about statistics because both virtual appliances have same configuration, but on Analytics report tab numbers are very different. (Attached print-screens)
Maybe there is some explanation why could it be?
patoberli
Check the top of the images. In one it's Associated, while in the other it's Connected. I think that could be the difference, but I don't know the CMX enough to help you more.
Well that should not be the case, because on CMX 10.2.3-34 - You can choose Connected, Detected devices and on CMX 10.3.1-35 - It changed to Associated, Probing Only devices.
Ok, then I probably can't help you.
Appears from CMX-10.3.1-35, the names are ammended to be more meaningful.
"Connected" being changed to "Associated"
"Detected" being changed to "Probing only"
The new names in actual makes more sense.
