Cisco Compliant TKIP Features want work with the Novell Client.
ClaiboTL
I've just installed the Cisco Aironet 1200 series Access Point G Model at 54mbs. With it I'm using the Cisco Aironet 802.a/b/g Wireless Adapter. If I turn on MIC ( Message Integrity Check) on the Access Point, I cannot login with the Novell Client or even the Microsoft Novell Client. If I turn off MIC on the Access Point, I can login just fine with both Clients. I have installed the lastest Client Drivers and also the lastest ACU. If I don't try and use Novell, I can login with the Microsoft Client with MIC enabled on the Access Point just fine. This of coarse want do since we hace a mixed shop of Novell and Microsoft. Is there a fix for this problem?
smahbub
Level 6
Level 6
If you are using Non Cisco client cards this would not work. If this is the case take a look at the following URL,
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c40b6.shtml
Thanks for the info. I just received an update for the ADU from Cisco yesterday. Version 1.1.0.10. Looks like they got the problem resolved.
This version is available on Cisco.com now for anyone else interested.
