WNM Not Authenticated
scherea
Community Member
I am trying to setup WDS and have on an access point and get the message that the WNM is not Authenticated. On the ACS Server it appears that both the AP and WLSE have passed authentication, any ideas?
chris.houston
Community Member
I had this problem when I first configured the WLSE with an AP with WDS. After playing with it, I found that the WLSE needs to discover the WDS AP first. Make sure the username and password match on the WDS AP and on the WLSE. Here is what I have on my AP. It took a while, but after having it rediscover the AP a few times, it finally took. This was with v2.5. I have not set up any with v2.7 yet. Also, check the help on the WLSE. I don’t have an ACS in this design. Hope this helps.
wlccp authentication-server infrastructure method_cisco
wlccp wds priority 255 interface BVI1
wlccp wnm ip address x.x.x.x
wlccp ap username xxxx password 7 xxxxxxxxxxx
(Fill in the information for the xxxxxx’s)
wififofum
Level 7
Level 7
You may also want to delete and rediscover the AP in WLSE. If users can authenticate then its something in the local wlccp infrastructure-authentication setup/method for WDS (WDS AP username, WLSE WLCCP credentials).
