cisco controller
i want to ask about wireless controller 5500  if :
1- It support roaming between APs ?
2- It support traffic load balance between APs  ?
 Ex :   two AP   AP1, AP2 with the same SSID and Password connected to wireless controller . the two AP lie at the same area only 10 meter between them so , any users can see both of them  . there are many user connected to the two AP but AP1 handle traffic more than AP2 . if new user come and his location near to AP1 , can controller make him connect to AP2 because it handle less traffic even if power of AP1 more than AP2 .
Note : i know that controller can force AP to refuse new user depand on Max user i configure but in my case i want controller force APs to refuse user depand on comparison between APs traffic they handle .
Amjad Abdullah
5508 supports client roaming between APs (assuing roaming requirements are met: i.e. same ssid, same security, proper overlapping...etc).
I think you ask about load balancing feature.
check this: http://goo.gl/QO9R0L
Amjad
Rating useful replies is more useful than saying "Thank you"
