Cisco Embedded Wireless Controller GUI not working
eduardo-sandoval
Community Member
Hi I have a Cisco Embedded Wireless Controller on Catalyst Access Points 17.8.1, with 3 AP 9120 AX connected to it.
Those 3 AP and the embedded one are connecting clients and working properly but the GUI is not working, it doesn't load.
I hope you can help me fix this issue.
jagan.chowdam
Can you ping the EWC being on the same VLAN?
Can you SSH into the EWC?
If yes, verify http & https enabled on the EWC
######## Enables web interface of EWC ########
EWC(config)#ip http server
EWC(config)#ip http secure-server
Are you using http:// or https:// to access EWC?
If both HTTP and HTTPs are enabled, the EWC always serves the user with its HTTPS web interface. It is crucial to have HTTP enabled for some features such as web authentication and it is recommended to have it enabled.
Which browser are you using to login? Try clearing browser cookies, use incognito mode. Use different browser and check.
Jagan Chowdam
/**Pls rate useful responses**/
Mark Elsen
   - Have a checkup of the Cisco Embedded Wireless Controller's configuration with the CLI command
     show tech wireless and feed the output from that into Wireless Config Analyzer
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I assume it worked before? Sometimes the browser need a clear of the cached files. Have you tried a private browsing tab?
And you really should upgrade.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Rich R
You're using version 17.8 which is a Standard-Support Release which will never get any bug or security fixes.  You should always aim to use an Extended-Support release (17.9, 17.12 etc) to be able to get bug and security updates.
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-xe-16/bulletin-c25-2378701.html
Refer to the TAC recommended code page (link below) for the current release to use.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
