04-28-2022 08:24 AM
Hi there - here is situation:
1. I have both a 9800-CL controller and EWC controller setup. Both have the exact same configuration. I would prefer to use EWC to controll my 9130AIX access points so I don't have to spin up the VM.
2. Using the 9800-CL controller in a VM each 9130AIX access point runs clean air fine. I can see cleanair statisics and it finds interferers.
3. On the EWC clean air does not seem to work. "Specture Operation Status" stay down even though it is enabled. The controller does NOT show any interferers, ever.
Does anyone know why this is happening? Does Embedded Wireless Controller even support clean air?
04-28-2022 04:14 PM
Searching on Cisco docs, we dont see any limitation on the CleanAir for EWLC. Can you provide informations about Software version from WLC?
04-28-2022 04:37 PM
I've tried 17.3.5, 17.6.3 and 17.8.1. All versions exhibit the same behaviour.
04-28-2022 11:36 PM
For me 17.3.4c and 17.3.6x all works fine and displays statistics.
The only thing I haven't noticed before is I was missing the Radio configuration section on GUI.Missing Radio Config
CleanAir Interface Status
Cleanair Stats
04-29-2022 03:52 AM
Are you running 9130AIX access points like I am?
04-29-2022 04:58 AM
This is a mixed environment with C9130 and C9120, but C9130 is the primary controller.
After consulting TAC about Radio configuration missing, this is a known defect on 17.6 train which is been fixed... maybe your issue is related to this so open a TAC case.
04-30-2022 06:00 AM
Interesting - I don't have the Radio Configuration missing issue in either 17.6.3 or 17.8.1 - my environment is mixed (C9130AIX and AP1562).
06-10-2022 02:38 AM
