 Cisco Identity Services Engine VM (eDelivery) - Part # L-ISE-VM-K9=
Wajma_2
I would like to know, if the following will run on Microsoft Hyper V. (Windows 2008 R2)
  • Cisco Identity Services Engine VM (eDelivery) - Part # L-ISE-VM-K9=
Thank you and best regards
Not applicable
ISE virtual appliances are supported on VMware ESXi 5.x and 6.x or KVM on Red Hat 7.x. A production deployment should be run on hardware that equals or exceeds the configurations of the current physical ISE platforms. For lab or testing environments that provide no product services, the solution can be run on virtual targets that have at least 4 GB of memory and at least 200 GB of hard drive space available.
