High Water Mark WLC 5508 7.6.120.0
garyleggat
webauthRedirect: Jun 10 13:13:07.452: #LOG-3-WATER_MARK: debug.c:2787 Hits the high watermark. Logging Critical, Alerts and Emergency messages only
Not sure what this means there is a problem at this site of clients not receiving  web page for log in access
patoberli
Looks like you hit some software bug (there are several similar bugs in the bug toolkit).
The whole 7.6 software train was deferred by Cisco (because of bugs and such) and should not be used. I suggest to upgrade to 8.2.151.0.
This was fixed in 7.6.130.0 and newer (it's just a small selection of the full list):
CSCuq36902
Memory Leak with Internal webauth in a loop for longer period
CSCuj05274
WLC Crash - Reaper Reset: Task “”loggerMainTask”” missed software watchdog
CSCuo86819
WLC crashes in 7.6.120.0 - memory corruption caused by Webauth
So yeah, I stand with the upgrade to 8.2.151.0.
