07-11-2018 08:33 AM - edited 07-05-2021 08:50 AM
I ran a system diagnostic on a 3850 running 3.7.5, using the Cisco CLI Analyzer tool, and received the following danger message:
Cisco IOS-XE System Diagnostics: Invalid # of commands for workflow steps: 174
I am trying to figure out what this exactly means and how to address it.
Terry
07-11-2018 01:50 PM
I would assume Analyzer tool is not updated with 3.7.5 command syntax.
Rasika
07-16-2018 11:05 AM
I am getting the same error message when I run the diagnostics on my 3850. Cisco CLI Analyzer 3.6.0, which is the only version I see on Cisco's website. Do you have a link to 3.7.5? I hope that fixes it for me. Thanks.
07-25-2018 06:44 AM
I am having a similar issue. Cisco CLI Analyzer version 3.6.0 - Cisco 3850 version 16.3.6. Error message is Cisco IOS-XE System Diagnostics: Invalid # of commands for workflow steps: 163.
08-30-2018 12:41 PM
Hello Terry,
Thank you for using the Cisco CLI Analyzer. The message you are seeing is due to the fact that we set a hard limit on the number of commands the CLI Analyzer can support to 100 per workflow step. This prevents the Analyzer from locking up by running thousands of commands at once and helps manage the amount of data output being sent back to Cisco as our API team sets a hard limit as well.
With the next release of the CLI Analyzer we plan on increasing the max workflow steps to 250 which should mitigate this issue, unfortunately we have no control over how many commands the Cisco back-end is sending so there is no workaround at this time.
Please let me know if you have any additional questions.
Joshua
08-30-2018 12:43 PM
