Cisco module controller & 1131 access-point
mel.farhat
Community Member
I'm using a blade as a controller in a cisco router. trouble is it does not see
the 1131 access-points. does see 1020 access points. Any thoughts
sethgarnar
Level 3
Level 3
If you are using OP 43 to tell the access points where to find the controllers you will need a new entry for the 1130 series of access points.
do you know that entry, we are usung a dhcp server at our head end.
Rob Huffman
Hi Mel,
One quick question are you running in Layer 3? The 1131 is not supported in Layer 2.
Rob
yes current mode is layer 3
