Cisco NCS missing SSID in default group
omer shtivi
In the NCS we got 5 WLANS
When we navigate to AP groups default-group wlans we see only 4 SSIDS
Any ideas?
Your talking about NCS... It defaults when you create it on the WLC, not NCS.
-Scott
5 Replies 5
Scott Fella
The NCS and WLCs do not sync their data. You must refresh the config from the WLC in order to have the same configuration info. So when you are under configure controllers, on the drop down on the top right is an option to refresh the config from the WLC. You click that and then don't retain the old info when it prompts you.
-Scott
Hi Scott,
I know that.
My qustion is how it possible that the SSID is configured in the NCS but it doesn't appear inside the SSIDs in the default ap group.
I even tried to recreate the problem with no success...
Please see the attachment.
Omer Shtivi
The attachement is hard to see... I beleive as long as you have the SSID defined in NCS, you can add that to the default-group.  I tend to create everything on the WLC then refresh the config and delete the old.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
When you create a new SSID it's automaticliy enters the default ap-group right?
Because in the default ap-group all the SSIDs always working.
So why is one of the SSID isn't appears inside the default ap-group?
-Scott
