Cisco Outdoor AP Not Being Recognized by WLC
Hello Everyone!
I hope all of you are doing great and would like to thank anyone in advance for taking their time to read this. I am sure that I am not the only one that has experienced this. I did find a couple of posts on these forums with the same/similar issue I am having. I have tried their solutions and it does not appear to be working for me, hence my new post. It's probably something simple that I am missing so I apologize for taking up your time, if that is the case.
Scenario:
We have installed a Cisco 1560 Outdoor AP however, it is not being "seen" on our wireless controller (Cisco 5520).
Details:
We have recently installed an outside AP (1560) and powered it up using its corresponding power injector. It has been connected to a switch (known good) and the AP's switchport has been configured to match other switchports being used for APs, so we know that's not the issue.
The AP is cycling through blinking red/green/amber lights, which according to Cisco, means that it's trying to connect to the WLC via discovery/join process. I have added the MAC address of the AP onto the WLC's AP Authorization List under Security->AAA->AP Policies (Certificate Type is MIC). The policy configuration of the WLC is set to accept MICs. I have also rebooted the AP after making these configurations/connections.
It is my understanding that at this point, the AP should be showing up on the WLC with its MAC as its name, perhaps under Wireless->Access Points->All APs. There may be some geographical settings that need to be made at this point, which is fine, but the problem is that it's not showing up anywhere on the WLC so I cannot make those changes. Again, I appreciate any and all responses.
AP: Cisco Aironet 1560 Outdoor AP
Wireless Controller: WLC 5520
Supporting Articles that I followed:
Cisco Aironet 1560 Series Outdoor Access Point Hardware Installation Guide - Troubleshooting [Cisco Aironet 1560 Series] - Cisco
The output won't stop you from entering anything on the console although it can be confusing.
That's why it's best to have all your commands in notepad and then paste them onto the console.
If you're not sure then practice on another AP.
22 Replies 22
Scott Fella
You have other ap's joined?
-Scott
Hey Scott, thanks for reaching out. I do, we have 50 APs on our WLC and they have been going strong for a couple of years now.
Okay... I would console into the ap and look at the output.  I would also perform a factory reset using the button on the ap, just to make sure.  Console output will show you what is going on.  Also keep in mind, that once you add a mac address, then you will need to add all the ap's ethernet to that list.  A reboot would prevent an existing ap to join once you have that checkbox enabled.
-Scott
Thanks Scott. I will take crack at that this morning and let you know if it works. I do have some questions for clarification.
"...then you will need to add all the ap's ethernet to that list."
***I am not quite sure what you mean by this. Could you elaborate? Thanks!
"A reboot would prevent an existing ap to join once you have that checkbox enabled."
***Also, if you could elaborate on this one, I would appreciate it. It almost sounds like rebooting the AP after adding the MAC was not the correct course of action.
When you enable AAA for ap policies, that is global to all ap's that will join that controller.  So once you add a mac address and enable "Authorize MIC APs against auth-list or AAA" that tells the controller to check the mac address list to authorize the access point during a join.
-Scott
Scott,
Ahh Ok I think I see what you are saying. Thanks for the pic. Are you saying we need to enable Authorize MIC APs against auth-list or AAA? I suppose what is confusing me is that we have 50 APs connected and doing just fine with the current WLC settings.
If we need to enable the setting, would this cause a disruption in wireless of any kind for already existing APs? I have to ask to avoid any prod down issues.
This is why some folks choose to have another controller for outdoor access points.  Now this doesn't make sense if you can't afford another, or if you have a few of these.  The thing to understand is you need to have authorize ap enabled in order for outdoor access points to join.  Now since this is a global setting, it will affect your other joined ap's.  Now..... this will not disrupt your existing ap's when you enable this, but you need to enter all the ethernet mac address to the list and then enable it.  You can script this out in the CLI if you wish... a lot easier this way.  This will ensure that all your indoor and outdoor access points will join.  Keep in mind that any new or replacement access points will need to be added to the list.
Just to clarify.... enabling the checkbox will not cause any disruptions.  What will cause an issue is if you don't enter the correct mac address and later on, the ap reboots, there is a power outage, etc. the ap will not join.
-Scott
I'm assuming you have another controller to test with?  This can help you play around with the setting and see if the ap joins or not.
-Scott
Hey Scott, thanks for the info. OK, I am not sure why this setting was disabled on our end. Perhaps my predecessor enabled it to allow the other external AP to join and then disabled it to prevent what you are describing with the reboots. I'll roll through a change control and get this knocked out tonight. I am not worried about it, just procedure for things of this nature.
We do not have a spare/dev WLC to test with.
Arshad Safrulla
Please refer the below article, 1562I requires uPOE, so there is a possibility you are low on POE. If you are using POE injector make sure that you disable POE in the switchport.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1560/installation/guide/1560hig/1560_ch3.html#:~:text=Table%203%2D1%20Access%20Point%20LED%20Signals
Add the AP MAC address here Security>>AAA>>AP Policies, Certificate type should be selected MIC, or directly connect to the AP via console and use command "capwap ap mode local".
Hi Arshadsaf,
Thanks but that is not quite our situation. Appreciate it though.
There a good blog here about AP Join Issues:
https://wifininjas.net/2019/04/19/wn-blog-001-ap-join-issues-with-cisco-wlc/
That being said for the outdoor APs (or any AP ordered as a MESH mode) you need to do exactly what you listed:
Add AP to security policy under the AP policy as MIC (Ensure its the ethernet MAC address, I would confirm from the switch port as have found the sticker being wrong before)
Few things to check:
  • Is the connected switch seeing the AP as a CDP neighbour?
  • Does the AP have an IP address
  • If you connect an internal AP to the same port does it register to the WLC (rule out any port config issues/ connectivity issues)
  • Can you console the AP and share the log file whilst it reloads
  • Share output of "show capwap client rcb" from the AP
  • Are you seeing the AP in the WLCs AP Join Statistics?
  • From the AP console try "capwap ap mode local"  - you may have to enable debug capwap client cli first
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Haydn,
I have confirmed that the switch pulls the correct MAC address. The sticker is right on this one
  • Is the connected switch seeing the AP as a CDP neighbour? No it is not. Which is strange since the AP's MAC is registered in the MAC table of the switch.
  • Does the AP have an IP address? Unknown.
  • If you connect an internal AP to the same port does it register to the WLC (rule out any port config issues/ connectivity issues)? I have not tested this however, the switchport configuration is identical to other switchports with working APs.
  • Can you console the AP and share the log file whilst it reloads? I will get those logs to you tomorrow. Unfortunately, I don't have access the AP at this moment.
  • Share output of "show capwap client rcb" from the AP. I will get those logs to you tomorrow. Unfortunately, I don't have access the AP at this moment.
  • Are you seeing the AP in the WLCs AP Join Statistics? I am not.
  • From the AP console try "capwap ap mode local"  - you may have to enable debug capwap client cli first. I will get those logs to you tomorrow. Unfortunately, I don't have access the AP at this moment.
If your not seeing the AP as a CDP neighbour or hitting the WLC in the join statistic I'm guessing it doesn't have an IP address. The logs will show
