09-12-2016 11:45 AM - edited 07-05-2021 05:48 AM
Dear all,
I never thought about that but after a discussion I'm no longer sure and would like to verify that.
By today I thought if I add some APs to the wireless maps that will have to influence to their function. But another person I talked to last week means it is very important to make the maps excact to have the APs function correctly.
So, for example I add two APs in a map and set them very close together just 5meter. In real they are 30 meters apart. So will the prime tell the WLC to shift down the power level? or something like that.
e.g. if the height ist not correct or so would that make trouble?
in conclusion, how much does the accurate of the map has an influence to the function of the AP? For me it was just a view tool by now.
Thank you!
best regards,
Sebastian
Solved! Go to Solution.
09-12-2016 06:40 PM
Hey Sebastian,
I used to think the same thing but the short version is no, CPI Heatmaps do not influence AP behaviour in any way, they are purely monitoring based on data sent back to the tool.
Cheers,
Ric
09-12-2016 07:03 PM
Ric is right! PI pulls data from the controllers and only pushes data for templates for example. Place ap's in one room and see if the RF changes.... I bet it will not. I don't even have the PI heatmap enabled as I only look at hostnames, channels, utilization and or client count.
-Scott
09-12-2016 06:40 PM
Hey Sebastian,
Cheers,
Ric
09-12-2016 07:03 PM
-Scott
09-12-2016 11:51 PM
Scott u won :). TPC 10min, after 10min no Change! with 4 APs in one room just 1meter apart.
Also thanks to Ric!
