09-20-2013 06:48 AM - edited 07-04-2021 12:53 AM
Is there a report in Cisco Prime Infrastructure 1.4 showing the unused switch ports?
There used to be one in Cisco Prime LMS (Reclaim Unused Up/Down Ports Report).
Thank you,
Luke
04-21-2017 09:22 AM
Using Prime Infrastructure 3.1.0 there is a report.
Reports/Report Launch Pad/Device/Port Capacity.
It is a little cluncky, and you have to sort through what the report produces, but it will give very similar information.
04-21-2017 11:30 AM
I'm running 3.1.0 but can't see that report. The options I have under Device reports are :-
AP Ethernet Port Utilization | New |
AP Image Pre-download | New |
AP Profile Status | New |
AP Radio Downtime Summary | New |
AP Summary | New |
AP Utilization | New |
Busiest APs | New |
CPU Utilization | New |
Classmap QOS Statistics | New |
Detailed Hardware | New |
Detailed Software | New |
Device Credential Verification | New |
Device Health | New |
Dmvpn Reports | New |
GET VPN Network Status | New |
Identity Capability | New |
Interface Availability | New |
Interface Capacity | New |
Interface Utilization | New |
Inventory | New |
Memory Utilization | New |
Non-Primary Controller APs | New |
Top AP by Client Count | New |
Unified AP Radio Downtime Summary(Deprecated) | New |
Vlan | New |
Wired Detailed Device Inventory | New |
Wired Device Availability | New |
Wired Module Detail | New |
Wired Port Attribute | New |
Wireless Up Time | New |
Wireless Utilization | New |
05-04-2017 09:59 AM
Attached photo is from Version 3.1.6.
But this report does not tell you when Ports where used the latest. It just tells you with what utilization limit which switch has how many empty/used/empty-down ports. again It does not tell when the ports where used the latest. And that is the report that we need. I saw a python script I'm going to test
08-17-2017 09:19 AM
In 3.2 there is a port reclaim report. Doesn't work for me, I run it on a switch that I know has unused ports and get this for a result
No data matches the specified criteria for the report.
10-10-2017 07:29 AM - edited 10-10-2017 07:31 AM
Port Reclaim Report is unfortunately NOT working as expected. "Unused Up" I strongly assume is for switchports that are operationally down but not administratively shut down correct? I have multiple ports that match this decription with last input and output status as "never" and all interface counters 0, and yet the port still does not show up in the Unused Up. I have synced the device and the device has been in this state for many weeks and still no dice in the report, regardless if I choose reporting period of 1 day, 1 year or anything in between.
Additionally this Port Reclaim Report is completely counter-intuative. In LMS4.2 I have the option to report all switchports that have not been used for x amount of time. The output of that report shows me all ports not used for the past 30 days. This new Port Reclaim report in Cisco Prime Infrastructure, when choosing "reporting period" of say 8 weeks, shows all switch ports that have been operationally down from 0 to 8 weeks; not ports that have been down for 8 weeks or more! Please Cisco!!!
