I have a problem about adding Spectrum Expert to WCS. We have WCS up and running in Windows Server 2003 at port 444. The Spectrum Expert runs in normal Windows XP workstation. I have configured Spectrum Expert to use self-signed certificates. When I first configured the Spectrum Expert to send data to WCS server, I just used the WCS-server's IP address. Spectrum Expert then tried to initialize the WCS connection, but finally it just said "WCS unavailable" at the bottom right in the window. I then tried to put the port number too with the IP to the Spectrum Expert's WCS-configuration (like "10.10.10.10:444"). After this the Spectrum Expert said that WCS is active. So from Spectrum Expert, the connection to WCS-servers seems to be okay.
When I try to add this Spectrum Expert to WCS with the IP of the workstation, it just says the following:
Error(s): You must correct the following error(s) before proceeding:
Error:Though the target host is reachable, the Spectrum Expert doesn't appear to be running on the host. Please confirm that 1) It is running, 2) It is configured to send interference measurements to this WCS and 3) The card is installed correctly in the sppropriate slot, and then try adding it again.
These errors comes anytime, when I try to add Spectrum Expert to WCS. I can ping each other and I even can get WCS-connection from this workstation to WCS itself via web broswer. So between these, the connection is okay. But in WCS, when trying to add Spectrum Expert, it doesn't matter if the IP answers or not. I even tried something like 1.1.1.1, which definetly should not answer, but still I got the same error message "...Though the target host is reachable...". But when I tried to add the port number too with the ip like "1.1.1.1:444" I get the following:
Error:The host at address '1.1.1.1:444' is not reachable. Please check network connectivity to this address and try again.
So, Spectrum Expert says that the WCS-connection is active, but when I try to add it to WCS itself, WCS just says that the Spectrum Expert isn't running. What I have done wrong and/or what I can do to get these two working with each other? Is there problems with using different port for WCS? WCS version is 5.0.56.2 and Spectrum Expert Application is 3.3.52. And it says at the title bar that it's "WCS Compatible".
Thank you!
Joni Louhelainen
