Cisco Standalone AP Product/Model Number : AIR-AP1852I-E-K9 problem
hamzaghazi
I have a new AP. I just entered a wrong config and tried to reset the AP to default factory settings. I am not sure if its in the Rommon state. But its not showing Cisco Controller>.
I want to configure it using Mobility express and assign a static IP. I am sharing the result of show running-config.
Also getting,
waiting for uplink IP address and reachable default gateway
AP Name : Not Configured
Admin State : Enabled
AP Mode : Local
AP Submode : None
Reboot Reason : Invalid Config File
Primary controller name :
Primary controller IP : 0.0.0.0
Secondary controller name :
Secondary controller IP : 0.0.0.0
Tertiary controller name :
Tertiary controller IP : 0.0.0.0
AP join priority : 1
Last Joined Controller name:
DTLS Encryption State : Disabled
Discovery Timer : 10
Heartbeat Timer : 30
CDP State : Enabled
Watchdog monitoring : Enabled
RRM State : Enabled
LSC State : Disabled
SSH State : Disabled
AP Username : Cisco
--More-- [*03/04/2020 08:56:41.2855] waiting for uplink IP address and reachable default gateway
Session Timeout : 300
Syslog Host : 255.255.255.255
Syslog Facility : 0
Syslog Level : 0
Core Dump TFTP Ip Addr : 0.0.0.0
Core Dump Flag: : 0
Core Dump Filename :
WLC Link LAG status : Disabled
AP Link LAG status : Disabled
#[*03/04/2020 08:56:46.2840] waiting for uplink IP address and reachable default gateway
[*03/04/2020 08:56:51.2824] waiting for uplink IP address and reachable default gateway
Please share any CLI commands or how I can reset to
marce1000
 - Seems like the AP  waiting to  get an IP address - configure your DHCP server accordingly afterwards you can convert ; here is a sample procedure :
           http://itadminguide.com/convert-capwap-cisco-1852i-access-point-to-mobility-express/
 M.
marce1000
 M.
