cisco vWLC MESH setup
p3tter123
Hi Guys,
I want to make a small mesh network with a vWLC. I know that some AP's have only 1x 2.4 GHz and 1x 5GHz antenna, so if you use I.E the 5GHz frequency band as back haul you cant use it for distributing WLANS
Which AP's could you recommend that have 2x of the 5GHz antenna other than the outdoor mesh AP's?
Petter
Scott Fella
I don’t believe you can do mesh with the vWLC’s. Also for MESH, you can add client access to the backhaul, however, depending on the traffic produced by clients, it’s not recommended. There are AP’s like the 3800’s that have a 5ghz radio and a Flexible radio assignment that can do 2.4ghz and 5ghz (one or the other). But it’s not meant to set it on 5ghz to use for backhaul. Also when the FRA is set to 5ghz, it’s a micro cell.
-Scott
Hi, its for between 5-10 Laptops, so not a big network. On the vWLC its called Flexconnect + bridge I think. would the 3600/3700 AP support clients in wlans on the back haul band?
Petter
