Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Vwlc ( virtual wifi controller ) password recovery procedure
nhedhili
Hi All
We need assistance about the Cisco Vwlc ( virtual  wifi controller ) password recovery procedure , we have an already installed Cisco virtual controllr on vmware ESXi , for which we need to do password recovery , if you have any documented procedure or send us how to do it that will help us a lot.
Thanks for your assitance
Leo Laohoo
Password recovery for a WLC also means wiping the config of the controller. Is this what you want?
Thank you for your reply,
if we are obliged to wipe the configuration and there is no other way  , please  how to do it enugh to get access to the controller and reconfigure it.
