Good wireless/Ap solution
laserlightit1
Community Member
I am looking for a stable wireless router or AP for my work place.. we have 9 lasers that emit a lot of interference with wireless signal. So im looking for a device that will help with the wireless signal stay active..
balaji.bandi
As you stated you have wireless interference in the place, suggest to contact local cisco partner who can help with site survey and suggest you the best product for your need.
BB
Leo Laohoo
Lasers, as far as I see, don't interfere with 802.11 wireless because both of them work in different frequencies.
Next, if you want to get the placement of the wireless APs done right, then organize to get a wireless site survey.  The cost of the APs are very expensive and getting one too many (or one less) can be a costly affair (to correct).
What Ap's are you using?? we are using Excimers and that seems to be the area's that give us the biggest issues..
