Cisco WAP4410N AP issue
vkumar63
I have an issue with my Cisco AP WAP4410N Device. The Wrieless Light does not come on and the Hard Reset of the Device does not work and I dont have the IP Address range of the device
Any Solution or help in this regard would be highly appreciated.
Kumar
5 Replies 5
marce1000
 - How are you powering the device and or does it   get sufficient power ?
 M.
I am Powering on the Device thrru an PoE Switch
Any Utility to find the IP Address of the Device which is not in the same network range
 - Issue show power inline  on the switch , check power being provided to the AP , compare this with requirements which can be found in the datasheet.
 M.
