Bookmark
Subscribe
2330
Cisco Wireless Android app won't connect to ME > 8.8.111.0
Maurice_
I'm using the Cisco Wireless Android app to monitor a Mobility Express system. This worked fine with all ME versions up to 8.8.111.0.
After updating ME to 8.8.120.0 the app won't connect any more. Error message: "Please enter valid credentials."
The credentials are correct and still work on the ME web interface. The app is the latest version from Play Store (1.3.320). I also tried ME 8.9.100.0, same behaviour.
Is this a known issue?
Cheers
Maurice
5 Replies 5
pieterh
Check if setting  "Mgmt via wireless" under the "Management" section of the controller is still enabled after the upgrade.
(using a wired connection)
This option doesn't exist in the Mobility Express GUI. Also, the ME web interface still can be accessed over the wireless connection. It's only the Android app that complains about invalid credentials.
I Have the same issue... +1
alain
arymar
Looks like there is a bug: CSCvp95449
A.
do you know if this is already resolved or there is ETA ?
l could not find this in the 8.5.151.0 release notes
