Heatmap for existing wireless network
waqas.arshad
Hi All,
How difficult it is to create a heatmap of the existing WAPs?
Waqas Arshad
patoberli
If you use something like Ekahau Survey or a similar tool, it's not that hard.
If you want to program something yourself, go for it. You need a client to walk around and measure the beacons from all APs at every given location and enter that into the software.
