Cisco Wireless Controller 2100 and CAP16021
hasanreza
Community Member
Dears,
One of our customer is having a Cisco AIR-WLC2112-K9 , we purchased an AP AIR-CAP16021-C-K9 , based on the supplier recommendation ,
As I understand , CAP16021x Series require a Wireless Controller with firmware 7.4.x and above where as Cisco 2112 can be last updated to 7.0.,
Is there a workaround available ,
In dire need of help and support,
Hasan Reza
ISHANT VARSHNEY
Hi Hasan,
1600 APs need minimum of 7.4 software on WLC and there is no way we can upgrade 2112 WLC to 7.4 code.
Only way to get 1600 AP register to WLC is to get a WLC which supports software 7.4 like 5508, 2504, WISM etc.
HTH.
Thanks & Regards,
Ishant
*** Please rate the post if you find it useful ***
Scott Fella
Just to add, keep this matrix handy for future use. This explains all the compatibility for Cisco wireless: http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html Please rate helpful post and Cisco Support Community will donate to Kiva Scotty
-Scott
Leo Laohoo
The only work-around is to convert the APs to autonomous IOS.
