Cisco Wireless Controller 2504 Software upgrade
marramix01
I am trying to upgrade a Cisco WLC 2504 from 7.0.116.0 to 7.4.121.0, but I am not able to find any information whether I have to upgrade the 'field recovery image as well. I am currently running the following software:
Software version:  7.0.116.0
with
Field Recovery Image: 1.0.0
Any help\guidance is always welcome
marramix01
kaaftab
Level 9
Level 9
you can find all the relevant information on the link given
http://www.cisco.com/c/en/us/support/wireless/2504-wireless-controller/model.html
Moin Ilyas
Level 8
Level 8
Please refer: http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68835-wlc-upgrade.html
mohanak
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_1_8_0_0.html
If you are using a Cisco 2500 Series Controller and you upgrade to the 7.4.100.0 controller software release and intend to use the Application Visibility and Control (AVC) and NetFlow protocol features, you must install Cisco Unified Wireless Network Field Upgrade Software, Release 1.8.0.0.
