Cisco wireless controller reboot reason troubleshooting and how to avoid WLC reboot ?
Tiandao
Leo Laohoo
Please provide more information.
What exact firmware is the WLC running on?
patoberli
Attach a console cable and watch what happens. It should log a crashfile and description when crashing. I assume you are running an old firmware with some bug though.
If it's an older WLC (not of the 9800 generation) you find the crash information under Management -> Tech Support -> Controller Crash.
Mark Elsen
                                 >how to avoid WLC reboot
 - Look at the current software version , if applicable and feasible upgrade to an advisory release for the particular controller platform. check if the problem remains in place or not.
 M.
