Cisco Wireless Controller Version 7.1.91.0 interoperability with 1131AG Access Points
CB90021204
Level 4
Level 4
I would like to upgrade my Cisco 5508 Wireless Controller to version 7.1.91.0. The release notes don't specifically mention that that WLC version 7.1.91.0 supports 1131AG Access Points.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_1_91_0.html
Has anyone tested this or know if they are compatible?
George Stefanick
1131 are supported
George Stefanick
1131 are supported
Thanks George
Leo Laohoo
Yes it is.  It's mentioned several times in the Release Notes as well as in Table 1-2.
Access Points
First Support
Last Support
1100   Series
AIR-LAP1131
3.1.59.24
