Cisco wireless controller with legacy access points
Eman.Bakri
Level 2
Level 2
Hi, I have cisco access points models 1602i and 1802i and want to purchase cisco 9800-cl controller.
Does these access points are compatible with and can join the controller or must change the access points to new one?
Thanks.
balaji.bandi
check the matrix : (looks to me like high level they do not support.).
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
BB
Arshad Safrulla
1602 is not supported in any 9800 platforms, however there is no AP model by 1802i, if you are referring to 1832i then yes it is supported on 9800 platforms and all codes released up to today.
Remember 1602 AP's are EOL and no longer supported by CIsco,1800 AP's are announced EOL and replacement is new Catalyst 9000 series or Cisco Wireless 9000 series AP's.
Cisco Aironet 1800 Access Points - Data Sheets - Cisco
sorry, it is 1852i
Can you share link with me about the compatible access points with 9800 WLC.
