Cisco Wireless Controllers and TCL
grabonlee
Level 4
Level 4
TCL is a remarkable tool to use to automate certain processes in Cisco IOS devices. However, I presume WLCs do not have TCL shell embedded. Does any one know of any scripting tool that could be used to automate processes on the WLC such as auto backup of config to tftp server when config change is detected. I have heard about using Expect, but not too sure about it.
Amjad Abdullah
Check this:
https://supportforums.cisco.com/docs/DOC-21757
you can use also a tool called kiwi Cattools. google for it.
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
Check this:
Amjad
Thanks. I think I have come across that thread in the past, but never really bothered. Guess I'll have to add EXPECT as another language to learn. Will also have a look at CATTOOLS.
Thanks a lot.
