Cisco Wireless
ironising84
Community Member
At my company we are currently using a Cisco WLC 5508 to manage our wireless network across 2 dozen+ office locations across the US and Canada.
We're starting to run up against the license limit of WAP's on the current controller. We're in the process of adding another (at least) dozen sites to our infrastructure, with 1-4 AP's per site. After looking at the cost to purchase additional seats on the controller we've begun looking at other options for our wireless needs.
Has anyone here run into this issue? And what was your solution? Did you pony up the cash for the additional seats on the WLC? I have trouble fathoming managing 75 WAP's without a single pane of glass to control them...
Mark Elsen
 - The 5508 is EOL and you can not buy licenses for it anymore. You may look at the next XE-based controller platforms, as AireOS is being phased out too.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
I'm sure this is a duplicate question that was asked a few weeks ago!  Anyway ...
Mobility Express (like AireOS soon to be retired so don't do that) or EWC for the new Catalyst 91xx APs are only for a single site which means 1 per site = 36 'panes of glass' not the single pane of glass he/she is looking for.
To avoid the question being asked again you really only have 1 viable choice for 'a single pane of glass' - upgrade to a new 9800 WLC (there's a whole range of different sized options to choose from according to your needs) and that will service all your sites.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Or alternatively you might look at Cisco Meraki, a cloud based solution, for which you pay a yearly usage fee. If you stop paying it, you can't use your wireless anymore though.
