cisco wireless
shaikh.zaid22
Level 6
Level 6
hi all,
we are implementing a dynamic vlan allocation in wireless network, via forescout nac.
the clients are first joining to ssid and getting the ip range, however, the clients are getting correct ip address only when they disconnect and connect back.
The WLC is cisco 9800 in between the client and NAC.
any guidance is appreciated
5 Replies 5
Mark Elsen
 - You may find this guide informative  https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/217043-configure-dynamic-vlan-assignment-with-c.html , I know it discusses ISE not forescout , but it would be advisable to review the document , also  review the 9800  current  configuration with the CLI command : show  tech   wireless , have the output analyzed by  https://cway.cisco.com/tools/WirelessAnalyzer/  , please note do not use classical show tech-support (short version) , use the command denoted in green for Wireless Analyzer.               Checkout all advisories!
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi marce,
I have done the config according to the above document. the configuration works fine, only when we perform a re-authentication from the forescout nac. That too we have to disconnect the client and connect back to take a proper vlan ip address.
i am planning to open a tac, since the debugs also not giving much info.
 - Ok, you can also do client specific debugging using these info's : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity  (if not yet done) , client debugs can be analyzed with  https://cway.cisco.com/wireless-debug-analyzer
Rich R
First question: what version of IOS-XE are you using?
TAC can be quite unhelpful when you use anything except ISE so good luck with that.  Best to get packet captures of the radius and full radioactive traces of the client to make sure Forescout is sending it correctly from the start and see how WLC is handling it.  There have been some bugs around dynamic VLAN allocation so maybe you're just running an old IOS which doesn't have those fixes but if your IOS is up to date (see links below) then I'd be inclined to think it's Forescout that's at fault.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Arshad Safrulla
Have you confirmed COA is enabled in Cisco WLC side? Enable it under the Radius server settings and also enable AAA override and NAC state under the policy profile. If still not working, then post a sanitized RA trace from a client.
