Cisco wireless
Manish Manwal
Level 4
Level 4
we have cisco wlc 9800 and have 25 ap connected to it. i want to reboot one AP through GUI. is it possible to reboot single ap with GUI portal??
THANKS
MANISH MANWAL
5 Replies 5
@Manish Manwal hi,
this will help you
https://community.cisco.com/t5/wireless/reboot-multiple-or-all-access-points-via-wlc-web-gui-or-cisco/td-p/2460654
Good luck
KB
DanielP211
Hello!
Yes. Go to configuration -> Wireless -> Access Points -> Select AP -> Under Edit AP -> Advanced and under Hardware Reset pres Perform reseto on the AP.
Over CLI:
AP name <name> reset
****Kindly rate all useful posts*****
is reset same as reboot ??
THANKS
MANISH MANWAL
Yes.
BR
Rich R
AP name <name> reset = reboot AP
AP name <name> reset capwap = simply restart CAPWAP state machine and re-join WLC which is much quicker and usually achieves all the same things we used to use AP reboots for.
You only need full AP reboot when there's a fault on the AP you want to resolve.  If you just want it to re-join to switch controller (eg after changing pri/sec HA settings) or pick up new tags then capwap reset is the better option.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
