Cisco WLC 5508 & HP Printer
stefan.mathys
I have some problems with cisco wlan systems and hp airprint.
I use two cisco wlc 5508, one master and one anchor.
the APs ar connectet to master wlc, DHCP and the breakout point to internet are on anchor wlc.
so far, with my android phone, i can connect and hav access to the internet.
now I will use an HP mfp printer (MFP M276nw) with Airprint. I connect the hp printer to the same WLAN to the same IP Range.
I can ping the printer from my android tablet but I never find the printer with an app from hp.
If I connect the same printer with the same tablet to an normal home-user accesspoint is every thing ok.
I think I have to configure something on my wlcs.
any ideas ?
thank you
Looks like v7.5 supports bonjour over anchor. You might want to look at this thread
https://supportforums.cisco.com/thread/2200019
-Scott
svibeesh85
Ok, Lets go through this. Can you please confirm if you have enabled multicasting and IGMP snooping in WLC.
Are your AP in multicast mode.
What multicast group traffic do you see on your WLC.
hi,
I have enabled "global Multicast" and "IGMP Snooping" on both WLCs.
I tryed the APs in multicast and unicast mode. Without success.
I dont have any multicast traffic on my wlc. where can I find this ?
We use Image 7.3.101.0 on WLC. Could this be a problem ?
-Scott
The above link is not working. Could you please provide me the valid link
