Cisco WLC 5508 WebGui and SSH not available in routed network
markus.bock
we have moved internal vlan routing from core switch to cisco asa.
Since the routing is moved I cannot access the web gui and ssh of our wireless controller 5508 over the management interface which is placed in another vlan where my client is.
I can ping it and in the internal firewall (ASA5545X) in the log a SSL or SSH session has been created successfully. But in my webbrowser is shown that the webinterface is not reachable.
When I put my client in the management VLAN where the wlan controller is pleaced in, I can access the controller via web or ssh.
Does anybody know a solution for this?
15 Replies 15
Where, how do you create that version of the 5508 config?
All I get from mine with a show run-config looks more like this:
(Cisco Controller) >show run-config no-ap
Press Enter to continue...
System Inventory
NAME: "Chassis"    , DESCR: "Cisco 5500 Series Wireless LAN Controller"
PID: AIR-CT5508-K9,  VID: V02,  SN: FCW1549L0GL
Burned-in MAC Address............................ CC:EF:48:B3:D5:20
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 500
Press Enter to continue or <ctrl-z> to abort
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.151.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... NAClab
System Location.................................. GP DC R10-28
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 172.22.10.15
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 22 days 1 hrs 7 mins 11 secs
System Timezone Location......................... (GMT -8:00) Pacific Time (US and Canada)
--More or (q)uit current module or <ctrl-z> to abort
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +34 C
External Temperature............................. +18 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 14
Number of Active Clients......................... 0
OUI Classification Failure Count................. 121
Memory Current Usage............................. 50
Memory Average Usage............................. 50
CPU Current Usage................................ 0
CPU Average Usage................................ 0
Flash Type....................................... Compact Flash Card
q
I did not see a Service Port or virtual interface entry.
and the management port ip a /16 spans  all the other interface addresses.
