Cisco WLC Aireos 5508 IRCM 8.5.176.2 Mobility Group 9800L 17.9.4a
ifabrizio
Level 3
Level 3
Dear All,
I have configured a Mobility Group between a WLC 5508 with 8.5.176.2 IRCM, and a WLC 9800 with 17.9.4a.
The mobility Group status is UP.
But in the Mobility Peer Configuration, I see that the 9800 status is N/A is it a problem?
Then I start to study the way how a client will be roam between the two WLC, that are on the same subnet, on this document:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-4/config-guide/b_wl_17_4_cg/m_vewlc_mobility.html
But when I check the "Guidelines and Restrictions" paragrps I see that the WLC 5508 is not in the list, of platforms that are supported for SDA Inter-Controller Mobility (AireOS controller–to-Cisco Catalyst 9800 Series Wireless Controller
  • AireOS
    • Cisco 3504
    • Cisco 5520
    • Cisco 8540
  • Cisco Catalyst 9800 Series Wireless Controller
    • Cisco Catalyst 9800 Wireless Controller for Cloud
    • Cisco Catalyst 9800-80 Wireless Controller
    • Cisco Catalyst 9800-40 Wireless Controller
    • Cisco Catalyst 9800-L Wireless Controlle
If this is true, how the IRCM realese works on 5508 for the clients roaming?
Bye,
JF.
marce1000
                                          >... I see that the 9800 status is N/A is it a problem?
  - Note sure , but for starting ; have  a checkup of the 9800 configuration with the CLI command show tech wireless ; and feed the output into  Wireless Config Analyzer
 M.
balaji.bandi
where is the Forien controller ?
cehck below attached document, if the WLC behind Public IP going across.
BB
Hi BB,
I am sorry I mean: foreign.
Rich R
Also note you should upgrade the AireOS 5508 WLC to 8.5.182.108 (link below).
According to https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_c9800_wireless_controller-aireos_ircm_dg.html and https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/ConfiguringIRCM/b-configuring-inter-release-controller-mobility-in-wireless-deployments-supporting-aireos-and-catalyst-9800-controllers/m-supported-platforms-and-releases.htm...  5508 is supported for IRCM
