managing client numbers connecting to an AP
wintersweat2000
Gday Everyone,
In a Lightweight AP environment, Has anyone ever managed to control number of clients connecting to an AP? or deny any clients connecting to the particular AP after a certain number of clients have already established an active connection to that AP?
7 Replies 7
Surendra BG
The below command on the WLC may help you.. but i am not sure that this is gonna work... but you can try once.. coz not even once this worked for me..
config advanced [802.11a | 802.11b] profile clients [global | ]
Few days back configured for a single client and i was able to connect my second as well so here is the enhancement bug raised for the same issue.. the next or next to next release may have a fix. here is the bug ID..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtj94508
CSCtj94508 -  There should be a way to limit the number of wireless clients that can associate to a lightweight AP. On autonomous APs, we have max-associations command.
lemme know how this answered your question!!
If   this helps you and/or answers your question please mark the question  as  "answered" and/or rate it, so other users can easily find it.
Surendra
Surendra BG
That would be a nice addition to the firmware.  Can't wait for this feature to be added to the next release!  +5
Surendra BG
Did that command work?
Surendra
Surendra BG
Hi Surendra,
Sorry mate, have not had chance to try your solution yet. Will let you know as soon as I do. Thanks for your help.
Hi.. No problem.. lemme know when you try that out..
lemme know if this answered your question!! pls rate the post if this was helpful..
Surendra
Surendra BG
Hi Surendra,
aint that command for only on radio interface a/b only. we are looking at b/g/n clients?
haha Bulls eye!! i expected this question from you!! at the time we configure 802.11B, the G in included.. i mean.. its represented as 802.1B but in this context 802.11B == 802.11 B/G..  even i dint know this, when i saw this for the first time long back.. here is thelink which tells that..
http://www.cisco.com/en/US/docs/wireless/controller/5.1/command/reference/cli51c1.pdf
Lemme know if this answered your question..
Surendra
Please dont forget to rate the usefull posts.
Surendra BG
