Cisco WLC OTP Authentication method
Ivane Sajaia
Frequent Visitor
Frequent Visitor
I am trying to set up SSID that will be authenticated using One Time Password,
i dont have much experience in this so for now im trying to do it using Radius, Tried Googling but every post is doing it with ISE...
if anyone knows way to do it with radius or some open source software.
My Setup is  WLC Cisco 2504 and Microsoft Radius Server
Scott Fella
If you are doing this for a guest, then majority of the radius servers don't do this.  ISE and ClearPass can, or else you just need a 3rd party wireless guest access solution that can provide this.  How would someone be able to get their OTP via text or email using NPS for example.  There is no SMTP integration or API to send messages to a user.  ISE has a 90 day trail, so you can always spin up a VM and give that a try.  Other than that, I don't think you have the equipment to do OTP.
-Scott
Scott Fella
-Scott
a50573329
is there any method t authenticate guest with otp msg through the NPS radius server as I doest has ISE in the environment
