Data sheet for the DC power adapter
Does anyone know where to find the datasheet for AIR-PWRADPT-RGD2?
8 Replies 8
balaji.bandi
other than description you do not see real datasheet i come across.
BB
No datasheet available. According to Cisco support, the adapter AIR-PWRADPT-RGD2 has han AC input and the output is 48V in DC with a power of 60W. The cable is not included so it will be necessary to add CAB-ACE or similar.
@pablomartinezmelero maybe you did not read the link in my reply last year below!
It includes a table with detailed specs amongst other info:
Thanks, but the question was concerning AIR-PWRADPT-RGD2 and your specs are related to a different P/N (AIR-PWRINJ-60RGDx=)
Rich R
I think the best you'll find is https://www.cisco.com/c/en/us/td/docs/wireless/access_point/power/guide/air_pwrinj_60rgd.html
fredn
Hi Fredn,
Would like to inquire is the AIR_PWRADAPT_RGD2, IP67 comply?
If yes, can I install this power adapter outdoor in the open, like in the Safe Zone of O&G plant environment? Any reference site which Cisco deploy this type of solution?
Thank you.
