Cisco WLC Web Admin Certificate Error
studmuffin
Level 4
Level 4
I keep getting a https error NET::ERR_CERT_COMMON_NAME_INVALID
while trying to use externally generated certificate
Windows server 2019 Default webserver Template
Did I do something wrong?
Error is on all browsers
10 Replies 10
balaji.bandi
check the cert installed correctly and are you using IP address or dns name ?
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html
BB
I use dns and i dont know exactly how to trouble shoot this?
accept the risk and check the certificate validity.
BB
It says the certificate is invalid
follow the above guide get a cert and install
BB
Is the common name just the host name and is it case sensative becuase in windows server dns i get to the controller by going to https://studmuffinwireless.studmuffin.com but the host name is StudmuffinWireless on the controller and the certificate is made out for StudmuffinWireless
I think i have an idea on  what is wrong
I use very modern browsers like you should edge chrome and opera gx do you think that might have something to do with it?
ok then try Firefox able to give access or IE is good for most WLC configuration ( chrome has some issue)
BB
Is this certificate actually valid?
Is the hostname (CN) in the certificate the same as shown in the browser URL field?
Did you include "Subject Alternative Names" which contains again the same name as the CN? (required for Google based browsers, like Chrome and the new Edge)
Does the PC trust the full certificate chain?
My pc fully trust the certificate chain and i checked to makesure the hostname is correct the only thing i dont get how to do i s the san's part
I don't really know open ssl enough to get that to work
